What's the meaning of Yield line mechanism parameter Yp?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: What's the meaning of Yield line mechanism parameter Yp?
BA
@BAretired exactly in Design guide series 4 of the AISC
Phi*Mnp = Phi*Fyp*Yp*tp^2
The Yp values vary based on the actual bolt arrangement and geometry of the plate. But, this allows the equation for the failure mode to look the same.
Just a way of simplifying the concept so that it can be more easily applied by a practicing engineer (as opposed to a PhD researcher).
In the derivation of the the derivation of the Yp values you do start with a plastic moment of plate per unit width (Fyp*tp^2)/4. But, they are eventually all wrapped up in that Yp value.
If you're interested in the original derivation of those yield lines there is a PhD thesis by Emmet Sumner titled "Unified Design of Extended End-Plate Moment Connections Subject to Cyclic Loading" which forms the basis for much of those AISC design guides. I'm sure there are other references as well, but that one seemed to be the most detailed to me as far as the derivation of the yield lines.
