Insert coordonate in Solidworks
Hi.
I want to insert a list of coordonate from a .txt file in Solidworks. The result is a point cloud. I want to connect some point with a line. I don't want a curve. Do you have a solution ?
Thank you.
RE: Insert coordonate in Solidworks
I would make a 3D sketch and place your points that way. Here is a link on how to place coordinate points.
http://blog.cati.com/2011/08/how-to-enter-points-w...
After you have your points you can either use the 3D sketch you already have or create another one and connect the points with the line tool.
Thank you, but a have a lot of point. It's a Survey for a elevation of a building. Enter point by point it's take a long time. My list is on .txt file.
Do you have another sugestion ?
Great, it's good.
Thank you.
