Air Quality for Liquid Sulphur Storage Tank and Degassing Pit
Could you please guide if which type - Plant Air or Instrument Air, to be used in Liquid Sulphur Storage Tank and Liquid Sulphur Degassing Pit?
RE: Air Quality for Liquid Sulphur Storage Tank and Degassing Pit
What will this "pressurized air at the molten pit" be used for?
In that service (whatever it is) what are the quality requirements (pressure, reliability, water levels, particle content, etc.)?
How much will be used at a time? (Maximum, minimum, average)?
How much can your current instrument air deliver at that location?
More generally, why do you think you have two independent sources of pressurized air at your plant that are called two different things with two different quality and reliability standards?
Utilization of plant air or instrument air would more than likely exceed the capacity of an "in plant" plant air / instrument air system.
Hope this helps:
Liquid Sulfur Tanks
[link http://www.sulphuric-acid.com/techmanual/Sulphur/s... Sulphur]Sulfuric Acid Resources[/link]
G. Hartmann
BS ChE NCSU
