Convert Japanese Catia V5 Files
We recieved files from our Japanese counter parts. We wanted to use there data to save time in remodeling. Is thier any way to change thier setting to our settings? We are currently running V5 Build 22 Fix 16 PLM is teamcenter. They are working on the same except thier PLM is Enovia. I also notice a publish certificate in the model tree that was rooted to the base part body. I was unable to remove by direct deletion. Thanks for the help if you can.
RE: Convert Japanese Catia V5 Files
CAA script can protect some element. Check with the source how they created this certificate and why you cannot delete it. (Maybe they want you to keep it anyway).
No need to keep the certificate it's not going back to our Japanese counter parts. I'm concerned that it will create errors in other models or assy's down the road. I remember making publish certificates before in Enovia but I don't remember their use.
I think you need to use some macros to find and replace strings in 3D.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
I don't know where I could find a macro to do this, we don't don't have a dedicated V5 admistrator on site.
Do you believe the model coming from a Enovia PLM and Saving to Teamcenter PLM will cause issues or errors to models down stream if used in larger assy's?
Would you recommend remodeling and drawing?
Don't know what to say....I never saw or work with Teamcenter....but did you tried to do some tests? What I can say is that a v5 administrator is not necessary a guy who knows also to do macros in CATIA...
Fernando
