Changing the group of an entity
Dear All,
The only way I know of changing the group of a curve entity is Group,(Point,Curve,Surface...)(Id, color, On Surface ...).
Is there a shorter way to achieve this? I tried selecting and then R-Clicking, but the option to change the Group was missing.
Rgds
Angre
Rgds
Angre
RE: Changing the group of an entity
If what you would to do is adding points ... associated to the curves. right click on the group containing the curves and select add related entities.
If not, explains more...
SN
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac – France
