Flexible plastic with good optical clarity and extrudable
I am looking for a suitable flexible, plastic product for making a closed extrusion for us which would be used outdoors (outdoor, flexible, plastic, extrusion)
We would like flexibility since it allows us to form extrusion around curved architectural features
Ideally, we want:
1) Optical clarity > 88% for 1/16" THK wall
2) Flame rating UL 94 HB or greater
3) UV rating UL746C f1
4) Operating temperature -40 C to 85 C
5) Temperature rating (RTI electrical) UL 746 > 90 deg C
Note that we are flexible on some requirements so we don’t have to have all our requirements exactly met
Plastic would need to be clear since we are inserting our light product within the extrusion.
Please let us know if you know of any suitable plastic which could meet our needs
Currently, we use polycarbonate for our extrusion, but with a flexural modulus of over 2200 MpA, it is too stiff
So far, the best option we found was a copolyester material from Eastman (Tritan GX 100) which has a flexural modulus of 1480 MPa
Cheers, Greg
Ideally, we want:
Cheers, Greg
RE: Flexible plastic with good optical clarity and extrudable
If you know of a flexible PVC which would meet our requirements, please let me know
I'm pretty sure that rope lights I've seen are extruded PVC.
http://www.tmi-pvc.com/flexible-film-rolls-extrude...
Chris DeArmitt PhD
President - Phantom Plastics LLC
Consulting, ideas and training on plastic materials
www.phantomplastics.com
I will further investigate flexible Clear PVC.
One issue we may have with this material is that it may be too flexible which could cause issues when material is extruded,and we want to retain consistency of shape
Our extruded profile is to be similar to rectangular tubing with aspect ratio of 4:1 or greater with approx 1/16" wall thickness
Please let me know if you know of any more rigid plastics which meet our requirements.
So far, Tritan Copolyester (GX 100), and Butyrate such as Excelon CAB, are best options I have found
Chris DeArmitt PhD
