What is a seed file? how do we crea
What is a seed file? how do we creat a seed file when we start project?
Lila
Lila
RE: What is a seed file? how do we crea
A seed file is MStation's term for a template. When you hit File/New, MicroStation makes a copy of your selected seed file and you give it a new name. The beauty of the seed file is that it can be used to standardize all new drawings that you create. That is because every new file that you create wil have the same global origin, color table, cell library attachments, working units, views, etc. as those that are in the seed file.
Also, MSta has configuration variables that, when set up properly, will point all MSta users on your network to the same seed files.
dscott
thanks
lila
thanks
lila
Hope this helps you.
I'm not working in V8 yet. I can tell you how to station a baseline using Microstation J and perhaps it's the same in V8.
On your Main menu, pull out the strip below your fence command and go to the block on the far right hand side. This command is Construct Active Pnt @ Dist Along Element. In the Point Type put in Character and in the Character box put in "X". In the distance box, put 50.
Select the beginning of your baseline (usually a PT), accept it in the direction you want to station, and then accept it. You should see an X appear 50 feet away from where you started. Now, change the distance to 100 and repeat the steps above. Each time changing the distance to +50 until you get your baseline stationed. Then you can go back and perpendicularly (is that a real word?) put in your tick marks.
This should help you until you get Geopak or some other software that will do it automatically.
