Where to buy "screw jack" screws & associated nuts/threaded blocks
We are looking for a direct source for 24 to 36 inch screws and matching "nuts" or "threaded blocks" of the type used in screw jacks like this
We can put this out on bid to fabricators but were hopeful we could find a large volume manufacturer so that we could gain the savings of buying a product already in wide use and direct from the manufacturer.
The screw should be capable of supporting several hundred pounds in a dynamic environment.
We may end up having to buy through a distributor but were hopeful of avoiding the extra markup.
Thanks for any help on sourcing these parts.
RE: Where to buy "screw jack" screws & associated nuts/threaded blocks
Have you tried McMaster-Carr ?
Chris, CSWA
SolidWorks 14
SolidWorks Legion
wholesales, retail and manufacturing
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
On the off chance you're in the UK, try Halifax Rack & Screw
http://www.roton.com/
http://www.nookindustries.com/
http://www.thomsonlinear.com/website/com/eng/produ...
http://www.rockfordballscrew.com/
http://www.haydonkerk.com/LinearMotionProducts/Lea...
Misumi
