Boundary Surfaces and Surfaces
Dear All,
Other than difference in their way of construction, is there any difference between Boundary Surface and Surfaces.
Or is it that,after they are constructed, there is essentially no difference between them?
Rgds
Angre
Rgds
Angre
RE: Boundary Surfaces and Surfaces
For example, go to Geometry / Boundary Surface / From Curves (or Alt+F11) select curves with closed loop (bounded) to create a boundary surface (it can contains holes).
Then you can convert this boundary surface to surface, go to Geometry / Surface / Convert. Depending on what are you working with, this method may be very helpful.
So, the boundary surface is one of the surface creation type.
Hope this helps,
SN
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac – France
So can I say that the boundary surface is a tool to create more sophisticated surface( for e.g surface with a hole )?
Rgds
Angre
SN
www.Innovamech.com
the main thing a boundary surface does for you is you can define the boundary (a closed set of curves).
Thank you all.
I was wondering as to where in the manuals can I find such descriptions.
The contents of the manual that I have seen are terribly lacking in providing the information that you have provided.
Or am I missing something here! Does there exist a manual wherein such an information is documented.
Rgds
Angre
this is the fastest way for me to find the information quickly.
SN
www.Innovamech.com
