How to insert an OLE object
When you copy (Ctrl+C) an image in Windows and paste it (Ctrl+V) in AutoCAD you get an image inserted in your file, not an external reference, but an OLE object. When I open this file in DraftShight I can see the image and the properties menu says it is an "OLE (1)" type object but I don't know how to insert this kind of object in DraftSight directly, the Ctrl+V method doesn't work. Any idea?
RE: How to insert an OLE object
Thanks for your help.
Thanks again.
