Problems with Firewal!!!
Hello everyone!
Anyone know how I can enlist rules in the Firewall for using NX license???
Because I can´t turn off the firewell on the server and will not let me connect to a client computer
Thank you
Thank you
RE: Problems with Firewal!!!
There is a line in there:
VENDOR ugslmd
Edit it so that you have:
VENDOR ugslmd PORT=28005
The 28005 is specifying the second port that the license server uses, so it's fixed and not dynamic.
You then need to create firewall rules for ports 28000 and 28005 to allow traffic through on both the server and client systems
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.3, NX10 Beta
Thank you very much for your answer !!!!
But I'm not sure how to make the input and output rule in the firewall
What rule I need to apply... TCP, UDP or both ports?
Thank you!
Anthony Galante
The NX works perfectly !!
