Surface to Surface interaction error in ABAQUS
Hello Guys,
I need help
In my model I have a block. The side plates are fixed to the central block using a nail or peg. The side plates are encastre at the bottom and a pressure is applied on top of central block.
When I use Tie constraint between (plates and central block, Pegs and Central block and peg and plates) it works fine.
I need to have a frictionless contact between the central block and the plate. I used Surface to Surface contact(standard),Sliding formulation as (surface to surface) and Interaction property as Tangential behavior (Frictionless).
I get the following error.
***ERROR: An error occurred during a write access to
C:\Users\ajay902\AppData\Local\Temp\ajay902_Tie_square_sTOsINT_2124\T
ie_square_sTOsINT_stdSolver.local_0 file. Check the disk space on
your system
Please help me.
I need help
your system
Please help me.
RE: Surface to Surface interaction error in ABAQUS
Aravindkj!
As indicated in the last sentence of your post, the problem is "the storage space" on the computer disk you are storing the results on (NOT with your model or ABAQUS). Check free disk space on the disk you are storing the output files of ABAQUS. You will certainly have insufficient storage space, compared to that required by ABAQUS for storing the output. Create sufficient free disk space, either by deleting unnecessary files or moving data on some other disk or storage. Run the software again. Most probably, you won't get this error again.
