components not displayed after loading a assembly
hi
I'm trying to help one of our nx users - but I'm going in dead ends.
Problems is . after loading a big assembly only a few (5-10) component's is displayed .
The assembly ( about 2000 component's) seems to be loaded very well - but not displayed . (they are NOT hidden or blanked)
But when staying in assembly navigator on the top note and rightclick and then press "Show" everything is displayed.
When saving and closing , and opening Again , the problen is still there.
Someone here on board - have you experienced something similar ? - and figured it out ?
lklo
lklo
RE: components not displayed after loading a assembly
Make sure all of the layers are turned on.
If you are in the model space then change to a differnt "canned" view. for example if you are in the trimetric view then change to something like the top view.
We have the same here in NX85 for some assemblies and cannot understand what triggers that behavior.
Changing the view does re-work the display of all parts correctly.
GTAC has been contacted and is working on the issue.
