Looking for the syntax for adding dimensions in notes.
I know that to add a dim in a note you can put it like this <X0.3@p6479> which shows like this .500 but if I wanted to add tolerance and show it like this: .495 - .505 How would a make this associative? Or is that an option?
RE: Looking for the syntax for adding dimensions in notes.
Are your drawings created using "master model" ?
<T+0,060!-0,030>
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
I sometimes try to get around with by using a real dimension in drafting. Add the tolerance values in. Hide leaders so only the dimension appears. Then add text before or after it. Unless you have a paragraph it should be ok.
