Mounting Light Switches
Greetings to all !
I would like to find out if there is a standard or a code regarding the
mounting of light switches near doorways.
NFPA 70 DOES require that electrical outlets [ snap switches ] be
installed within a certain height range [ vertically ], but is
there a code \ standard to require the same switches be installed
within a certain distance near [ or conversely ] ...away from
doors ?
Thank you for any input.
