How to locate and dimension datum targets in drawings and modify there locations in a drawing.
I created datum targets in a drawing and added dimensions and I understand that. I want to know how to modify the dimensions locating the datum targets to move them etc dim 25 needs to be 20.
Thank you,
Jeff
RE: How to locate and dimension datum targets in drawings and modify there locations in a drawing.
Double click on dimension and change it.
I don't like the datum targets in SW. They don't usually work quite as they should.
Usually, I attach the datum targets to a sketched entity, e.g. draw the target as a sketched circle on a drawing view and attach the target to the circle with a plain leader.
