Specific Weight of Materials Reference
Anyone know a good reference for this info?
Using NX (CAD program) I can get the volume of my tooling but I need the specific weight of the material to calculate the weight.
I haven't found a good site to get this info. I'm using English units also.
Materials such as Alum. 7075, 8620 steel, 4140, Magnesium, etc.
RE: Specific Weight of Materials Reference
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
However, I would ask if each of your CAD part models has the correct material density applied? Just knowing the total volume of your tool assembly times a single density will not give a correct weight if there are different materials used.
