AC sizing for residences with large window surface
Looking for design help AC sizing for residence with a large window surface area. Can we include the window coverings (blinds, curtains etc.) shading when sizing the AC? The issue is for new homes, where the window coverings are not provided by the builder. The designer sizes the AC for the maximum solar load, which is considerable for some condo/apartments with floor to ceiling windows.
If the owner then installs window coverings, the AC then becomes grossly oversized which has its own issues. However if the owner does not install coverings, and the designer sizing considers shading, the AC could be 30-50% undersized. Does anyone have experience with this for Canadian regulation? Legally, is the owner expected to install window covering?
Thanks in advance for your help.
RE: AC sizing for residences with large window surface
HRAI does allow you to design to as low as 80% of the cooling load.
that is the only way. it can be also helpful for client to be well informed about how much decision on shades affect things. he can, and must make decision than.
do not allow by any means to be bounced back by "do as you deem appropriate"; in cases like this one that's the way to ruin your career.
