Reference sets in asm
In an asm. whenever I double click on a component to change the work part, the reference set keeps changing to the model.
Is there a setting I can change so that when I double click on a component to make it the work part, the reference set would stay.
UGNX 8.5
Thanks!
UGNX 8.5
Thanks!
UGNX 8 / 8.5 / 9 - Windows 7 64bit
Productive Design Services
www.productivedesign.com
RE: Reference sets in asm
www.nxjournaling.com
When you make a certain part the work part in the assembly you are able to make changes to it as if you were in the part itself, including adding datum planes and features that include sketches that won't show up in the model reference set.
