Question regarding Heat Exchanger Nameplate
I've seen a U-Tube Heat exchanger designed to EN13445 to have a nameplate which contains the field:
TYPE/SIZE: BEU / I/DIA x STRAIGHT TUBE LENGTH
Where is this derived from? Is this any old ASME Practice because I can't find any info about it.
What is the practical benefit of having the I/D and Straight tube length stamped on the nameplate. Who does it help On Site?
Thanks!
Thanks!
RE: Question regarding Heat Exchanger Nameplate
What about tube size, pitch, tube count and baffle arrangement? Because on this particular nameplate there is nothing else than design, test & operating temperatures and pressures, and contained fluid.
What is the chance anybody would be able to read this information after 20 years of service on a offshore platform in salty water?
Just thinking.
