Change the cancel button on parameter editing
There are 2 cases in which I just hate the cancel button in inventor.
When you want to change te name of a parameter and you accidentaly type like "Lengthµ" Inventor gives the error: "variable name contains invalid characters" and this message only has a "cancel" button where an "edit" button would be more in place.
http://i58.photobucket.com/albums/g278/BeliMawr/pa...
And also when you are edititing the value of a parameter and you make an error or hit the return button a bit to soon and when you're almost done typing a long formula or are editing the parameter and you make a sudden error or something like that you get: "Unable to parse equation" and, idd, only a "cancel" button where also an "edit" button would be more in place.
http://i58.photobucket.com/albums/g278/BeliMawr/va...
Is there any but any way to change that button because it makes me kind of angry some times.
Thx. Beli
