Default Template Options
I have a question regarding the default options when you click on the down arrow next to the Hole options. The part template has the hole option defaults for the drop down set, somehow in the template but the sheet metal templates have only the defaults.
How do you choose to save the defaults in the sheet metal template? When I try to save a hole configuration in the sheet metal template, it seems to create a file called custom.xml but whoever did this before me managed to get them saved in the part template.
RE: Default Template Options
The intent of the Custom.xml file is that it can be stored on a network share and referenced by all users by changing the File Location setting in the SE Options.
Ken G.
http://grundey.blogspot.com
Have you checked out the Solid Edge Community site?
http://community.plm.automation.siemens.com/t5/Sol...
