Help with pipping recommendation for a series of tests.
Hello everyone.
I have very little experience with pipping and I need some input. I have 12 rows of 12 tanks equaling 144 tanks. The water is stagnate and I need to continuously filter out the water. I cannot cut into the tanks so i have to go over the top into the tanks (for both suction and discharge). The tanks are 6ft high by 5x5ft (1200gals). I want to run 12 tanks off one pump and one filter. So i'll have 12 pumps and 12 filters. The problem I think i will run into is uneven amount suction flow to discharge flow causing a tank to overflow if i run off one manifold. The tanks are side by side in a straight line and the pump/filter will be on ground level. The furthers tank from the pump would be 60feet away. I really don't know how to go about this. Any recommendations would be great.
THANKS!!
Materials on hand: 144 Tanks; 12x12 rows
12 Pumps (2HP, Variable speed)
12 CS filters (pool/spa)
2" PVC piping
THANKS!!
2" PVC piping
RE: Help with pipping recommendation for a series of tests.
