Washer over long slot hole
Hi everyone,
I was wondering if by thickening the plate washer, I would get away from covering the total length of the long slot (3"). If not, this would mean that at a spot where my bolt is totally at one extremity of the long slot, I would need a plate washer of about 5 1/2" long!
RE: Washer over long slot hole
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
RCSC Specification Section 6.1.2. Slotted Hole: when a slotted hole occurs in an outer ply, an ASTM F436 washer or 5/16 in. thick common plate washer shall be used as required to completely cover the hole.
The Canadian S16 spec has similar provisions (Clause 22.3.5.2(c)(ii) and 23.4.2(a)) although they seem to be restricting the requirement to pre-tensioned joints only.
Nope still no scientific explanation as to if we can use thicker washers while not covering the whole slot.
It sounds a little like a thing that can be verified with equations from that Roark And Young book, very tedious checks...haha
