Help with an easy script
Hi there,
I need some help with a project that I am involved in. It is the study of the heat transfer of a drilling. I need to make a script that make a simulation of the heat transfer while the drill goes into the piece. (See the image to understand)
I have already done the first simulation, and with it, I have created a .py as ordered as I could. What I need now is to know how to create a loop of this job, making each one deeper. I think is easy, but I can't find any information about this. I read PYTHON SCRIPTS FOR ABAQUS LEARN BY EXAMPLE, but the preview version is not enough for what I want.
If anybody could say me anywhere I can find information, or any similar example, It would be really helpful to me. If anybody have any idea of how to solve it, even better of course.
I upload an image of what I need to do and I also attach the .py file of the first simulation.
Thanks very much for reading this.
RE: Help with an easy script
In your newly created script for the first simulation, all you have to do is replace the depth information in the geometry as a parameter. Then using different values for that parameter manually, or iterating in a loop, you will create multiple input files. And then you can submit all those together.
Thanks for your reply. The problem is that I don't know how to do a loop and I don't know how to name parameters to the depth information. Do you know any example I could use to see how it is done?
Regards.
I do know how to parameterice the coordinates for the deepness, but I do not know how to do it for for example the name of the job, that should be changing like: job1, job2, job3... Also, I need to know how to do it with the Model name. Do you know what I mean?
Regards.
You can always put everything inside a loop, an example for three depths:
depths = [d1,d2,d3]
for n in range(3):
depth = depths[n]
jobname = 'job-' + str(n+1)
<Your code, replacing the appropriate parameters>
I did (n+1) because "n" will start at 0.
