Bend Line Tangents NX9
I have attached a mm and a dwg on the dwg there is a dimension in NX6 Showed a line at the end of the radius in nx9 it doesn't any one know how to turn these on
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.1.3(Testing)
If you can think it it can be modeled
RE: Bend Line Tangents NX9
If so, I think you'll find that the color for the 'Intersection Symbol' was set to 'Black' which means that they might actcually be there, you just can't see them. When you create your symbols, make sure you check in the 'Settings' section of the dialog and in the 'Style' area make sure the 'Color' is set to something that you can actually see. This is one reason I always work in 'Monochrome Display' mode when making drawing as everything is rendered black on white irrespective of the actual color assigned to the Drafting objects.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
