CAM-convert IPW
CAM-convert IPW
CAM-convert IPW
Hi Friends
I need convert an IPW in order to select a face like a plane.
Any suggestion?
Thanks in advance
Euao
RE: CAM-convert IPW
I think You cannot do it with NX, but there are other CAD systems.
In other case You can lay a plane on three points created 'on surface' of the facet body.
kukelyk
RE: CAM-convert IPW
For what do you need to select the IPW?
Mark Rief
NX CAM Customer Success
Siemens PLM Software
RE: CAM-convert IPW
In order to use it to create planes to build a fixture.
RE: CAM-convert IPW
If you turn on "Point on Face" on the Selection Bar, you can pick points on the facet body of the IPW to define planes.
Mark Rief
RE: CAM-convert IPW
Thanks.
Is the solution I used now.
But I´d like something better.
Is possible?
