View dependent Curves in model views (TFR ISO)
How to make View dependent Curves in model views (TFR ISO) to NON dependent? Check mate does not pass if Curves are View dependent.
Thanks in advance
Srikanth
Thanks in advance
Srikanth
RE: View dependent Curves in model views (TFR ISO)
Do you know why those curves are view-dependent ?
So now I'm thinking you might have the naming wrong?
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
To make Srikanthaallu's question more clear I explaining the issue once again, when the checkmate is run for a model we are getting the error like "No view-dependent Geometry allowed checker". Can any one explain how to resolve this issue?
The initial post seems to indicate that the view depenent curves are on the modeling side. Are they? Or are they only present in a drawing view?
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
www.nxjournaling.com
View (pulldown) toggle Display sheet off
Edit (pull-down) -> View -> View dependent edit -> In the "convert dependecy" section of icons select view to model -> pick those curves that need need converted from view dependent to model -> OK
View (pulldown) toggle Display sheet back on
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Your solution has worked for Nx8 also. Thanks for your valuable solution which saved my time.
