Can I deform the NX component which has instance geometry ? I tried but failed. Is it expected ?
Can I deform the NX component which has instance geometry ? I tried couple of way but unable to deform. Is it as designed in NX8.5.
What can be the way to deform instance geometry in higher level assembly? Your responce will be apreaciated.
regards,
sandip
RE: Can I deform the NX component which has instance geometry ? I tried but failed. Is it expected ?
Can you provide the part file or at least a picture/sketch of what it looks like and what aspects of it are instanced? BTW, are you using 'Pattern Feature' or some other function to create the instances?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Sorry I am not able to share part file. But I am using instance geometry feature to create instances. One sing feature created as a involute shape and created 30 circular instances.
Thanks for your prompt reply
Sandip
A picture or something would be a big help. Also some indication as to what it is that you're deforming.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
