Insert - Dimension - Feature Parameters
Is there a replacement for this legacy function in NX9 ?
NX 9.0.3.4
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
RE: Insert - Dimension - Feature Parameters
When creating your Drawing and you wish to annotate a 'hole' feature, use the 'Radial' dimension function and change the 'Measurement' 'Method' to 'Hole Callout'.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
NX 9.0.3.4
NX 10 (Testing)
That being said, the old 'Feature Parameter' function is still available, although with NX 9.0, out-of-the-box it's hidden. Now you can either simply enter the term 'Feature Parameters' into the 'Command Finder' field at the top-right area of the Ribbon and you'll see the function item which you can select to execute the function. If there's a chance that you're going to be using this function frequently, if you hover your cursor over the 'Command Finder' item for the 'Feature Parameter' function, you can then select the 'down arrow' at the Right of the and you'll be given several options as to where you can place the icon for this function to make it more accessible (remember to update your Role so that this change is made 'permanent').
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
