How to do a wedge analysis for a dead man anchor
Hi im trying to calculate if a dead man anchor with the following specs would be sufficient provide enough resistance for a HDD drill rig.
How would i calculate the forces and what factors should i consider?
A steel fabricated water filled buried container (known as a fabricated dead-man). The dimensions of the steel container for the 500 ton rig could be L x W x D = 5m x 2.5m x 2.5m.
The maximum pull capacity of the drill rig is 200tonnef
Any ideas would be greatly appreciated
Thank you
Thank you
RE: How to do a wedge analysis for a dead man anchor
f-d
¡papá gordo ain’t no madre flaca!
