Joint Efficiencies
Joint Efficiencies
Joint Efficiencies
Part UW-12 (d) of ASME Section VIII states that E=1.0 for circumferential stress calculations when the requirements for UW-11(a)(5)(b) are met, and E=0.85 when UW-11(a)(5)(b) is not met or when the welds are types 3-6.
Does this cover both type 1 and 2 welds?  Is there any situation where the circumferential stress calculations on a seamless vessel section or head would have an E=0.65 due to non-radiographed Category B, type 2 circumferential welds (UW-12 (d) does not specifically identify type 2 welds as it does with the others)?
z9rjword
RE: Joint Efficiencies
I think the UW-12(d) covers type 1 and 2 welds. I argue as the longitudinal weld generate more risk than the circumferencial one. In the case you mention we are more safe than in vessel with cat. A weld. Perhaps, ASME had explicitly to clarify this.
According to Table UW-12, you can use E=0.65 for type 2 cat. B weld with no ray examination.
Not sure to understand what you are in doubt for.
UW-12(d) states that E=1.0 if (in brief) the circumferential welds (be them of type 1 or 2) are at least spot radiographed, E=0.85 otherwise.
This is applicable to calculations that involve the circumferential stress in shell. When you calculate the thickness of the shell based onto the longitudinal stress, you'll take for E the value applicable to the circumferential weld, whatever is it (possibly 0.65).
prex
http://www.xcalcs.com
Online tools for structural design
Dear z9rjword (Mechanical)
Please go to the following http://www.nooter.com, download the ASME Quick Reference Guide. ASME SECTION VIII DIV 1, Pressure Vessels, by Nooter Fabricators.
Leonard
To Isthill,
Nooter no longer offers that ASME Quick Reference Guide.  Could you email me a copy (alan@pce-inc.com) or do you know of another location.  Thanks,
alan54
RE: Guidebook for the Design of ASME SECTION VIII PRESSURE VESSELS: PAGE 246 APPENDIX A FIG A.1 ASME Quick Reference Guide ASME SECTION VIII DIV 1, Pressure Vessels, by Nooter Fabricators.
