Heat Exchanger Maximum Inlet Velocity
Looking for a standard or publication stating maximum inlet velocity recommendations/restrictions for heat exchangers or different varieties. I am designing a cooling water system where one of the consumers specifies 185 GPM and DN 50 connections to the heat exchanger. Inlet velocity is in excess of 18 fps which appears high. Want to review velocity standards for heat exchangers to see if this is appropriate. Your comments are welcome. Thanks.
RE: Heat Exchanger Maximum Inlet Velocity
you must get smarter than the software you're using.
