Dimension leader attaches to geometric tolerance box instead of dimension
hi All,
I face a weird problem in solidworks 2014 drawing with the geometric tolerance box attached to dimension. when i specify a geomtric tolerance and attach to a dimension, the arrow points to the geometric tolerance box instead of the dimension. does anybody face a similar problem?? any solution? attached a screenshot of the issue.
RE: Dimension leader attaches to geometric tolerance box instead of dimension
Anyways thanks again.
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum Policieswww.superATV.com
www.scottjbaugh.com
Shashi
