Bringing Wire into a Pressure Vessel -- How to Properly Seal?
Hey guys,
I'm trying to bring a coaxial cable into a pressure vessel, through a wall or fitting, and I'm trying to figure out an off-the-shelf way to make the seal. I needs to hold 150psi.
A Swagelok would work in theory, but the cable isn't a standard dimension. It's a little under 7/16" thick. How can I handle this?
Grant
Grant
RE: Bringing Wire into a Pressure Vessel -- How to Properly Seal?
Mike
Just a few questions.
- What is the commodity in this vessel?
- What is the maximum operating temperature for this vessel?
- What does the cable connect to inside the vessel?
- Why are you doing this?
Sometimes its possible to do all the right things and still get bad results
Pennpiper,
It's crude oil and the maximum operating temperature is 90degC. It's connecting to a bus bar.
Thanks in advance.
Grant
Buy a pass-through pressure fitting intended for this purpose. Do such exist for coax connections? I don't know, but Conax is a good place to look.
Unfortunately, I forgot to mention that I'm wiring 70kV into the vessel via that cable. Everything from Conax is 8kV or less.
This is why I thought it'd be best to pass the cable itself through the vessel since it is pre-insulated for the voltage. Don't worry about the cable corroding, it won't.
Thanks for the continued support, btw.
Hopefully we can figure this out.
CocytusME
If the cable BLOWS OUT, 150 psig will be propelling 90 C scalding crude oil out of an open hole.
My bet is that the latter represents a far greater risk of injury than the former.
