Cable Tray - Steel Support Frame
Hello there.
I am designing a 3D frame inside of a building to be used to support a cable tray running across the length of the building. The cable tray runs the entire length of the 3D frame I am designing at the same elevation off of the ground. The cable tray is 3' wide and 4" deep and weighs 3.24plf. The frame I am designing is 20'-6" long, 10' high and 8' wide.
What is the best way to assign the loading of this cable tray to the frame I am designing?
Thank you. :)
Thank you. :)
RE: Cable Tray - Steel Support Frame
Michael.
"Science adjusts its views based on what's observed. Faith is the denial of observation so that belief can be preserved." ~ Tim Minchin
I’d go with 14.3984789kips/ft. of tray length..... Alternatively, you will have to investigate what is going to be on that cable tray, in terms of the total weight. Then, add some percentage (how much?, I’m not sure) per foot because the contractor will likely do that, in any case. But, you say a 3' wide tray, and an 8' wide support structure, so they can potentially add 5 more feet of cable trays or pipe lines to your support structure and they likely will. Then you locate those loads on the cross members to cause the greatest beam bending moments, and then, again, near the ends of the beams for max. shear and column loading, unless you can really control there locations. Then, they’ll probably hang some off the sides too. That’s some of the stuff of real engineering, not a textbook problem where all of the needed info. to solve a narrowly defined problem is given. You should discuss these kinds of questions with your boss/mentors, at your company or within your industry, there must be some basic standards as a place to start. This is the best way for you to learn, not by asking a group of people who can’t see what you are dealing with.
In particular, @dhengr thank you for the detailed response. I have now accounted for additional cable trays being added to vacant space onto the frame because of your advice. After discussing with my lead, this is typical within the process industry. It seems typical to be rather conservative as a structural engineer in this line of work.
