type of failure magnetic coupling
we have overhung pump is coupled to motor by magnetic coupling i need to know type of failure for magnetic coupling
RE: type of failure magnetic coupling
The only failure mode of which I am aware is an overtorque situation, where the magnetic coupling 'slips a pole' (actually two). In small magdrive pumps, it produces some acoustic noise.
Mike Halloran
Pembroke Pines, FL, USA
If there is too much slip, on eddy current type couplings, there can be excessive heat buildup and component failures due to high temperatures.
Are you actually suffering failures, rateb, or are you filling out some paperwork?
Mike Halloran
If you're talking about a pump driven by a wetted magnet, as far as I know the principal modes of failure are dry run (even very brief dry run) which leads to failure of the ceramic bearings/bushings the instant they are hit with cold liquid, or debris/solids leading to plugging of the flow passages between the magnet and outer "can" which leads to overheating and failure of the bearings/bushings or the magnet itself.
