HDPE Pipe
HDPE Pipe
Hi All,
Can HDPE Pipe 1000mm PN16 burried 90m below on tailing dam?
RE: HDPE Pipe
I assume that you're asking if the pipe can withstand the pressure of 90m of earthfill. Since the lateral and vertical pressure on the pipe are very similar, I can't see why it shouldn't work. On the other hand, actually installing the pipe to that depth could take some doing!
JD
RE: HDPE Pipe
Actually the pipe is laying on tailing dam area and burried step by step
