NX 8.5 going slow during sketch
thread561-343720: UG slow down, sketcher?
I have A surfaces and creating sections of B surfaces with reference with section curves (splines). But during sketching for every line i draw nx shows sketch updating and it takes lots of time. I am offseting splines for B surfaces.
RE: NX 8.5 going slow during sketch
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
While you can 'Trim' a Spline created in a Sketch, it will lose it's internal parameterization (its knot points will no longer to editiable or constrained). You can't 'Extend' a spline created in a sketch.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
can you create a demonstration example with similar sketches and upload ?
Else it's like leaving your car at the garage with a note on it, "there is something wrong, please help."
Tomas
We actually take a section section from 3d surfaces or solid bodies, then project those in sketch to propose a section for same. Consider a car window seal, when section curve are taken, there are 300 splines. So we project that in sketch.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
It's makes no difference whatsoever whether you select one or a hundred splines to project into a sketch, if they're all going to be projected into the same sketch. Once any curve is projected into a sketch, it becomes a single sketch object. If multiple curves are added to a sketch in a single operation, nothing different happens than if they had been added one curve at a time.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
