Light weight representation problem
Whenever I use "Use light weight representation" in load options to load large assembly files, after loading when I press the Center mouse button to rotate the assembly Unigraphics will close automatically. Again I have to load the entire assembly switching off the light weight representation in the load options.
I am using UG-NX7.5
Is there any way to avoid this crashing?
RE: Light weight representation problem
If you're crashing NX, and you can reproduce it and you have syslogs from these sessions, please contact GTAC and have them look at this as this is not anything that I've ever experienced.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
