On the Question of Framing a Complex Architecture Without Building Joints In Steel.
Pals
I have a 2 story complex structure to frame using steel frames and a few shear walls. The building is on high seismic region. It is almost impossible given the architecture to introduce building joints. The plan is quite complex with some hefty areas on the left, other hefty ones on one right upper corner and several weak areas bridging in between.
The area covered is substantial, around 450ft (150m) x 450ft(150m)on plan.
Will thermal and dynamic analyses, without joints, do the job? If yes, can this be defended by code?
Are there buildings in the world that perform just fine without joints?
I am interested in the outlier cases. A suggestion on literature will be just fine.
thanks in advance
respects
IJR
thanks in advance
respects
IJR
RE: On the Question of Framing a Complex Architecture Without Building Joints In Steel.
1) Like Hokie, I'd recommend including movement joints.
2) I believe that, with a suitably comprehensive thermal/dynamic analysis, you could justify omitting the joints.
3) I expect that the chord forces and thermal stresses generated by #2 will lead you back to point #1.
It's worth remembering that temperature swings during construction will exceed those experienced when the building is enclosed. I've had the misfortune to see the embedment for one of my mission critical steel drag struts ripped out of its supporting shear wall by thermal strain during construction. For what it's worth, my drag strut was very long and my world is very cold.
The greatest trick that bond stress ever pulled was convincing the world it didn't exist.
