MagicSmoker. LOOK! I got you another post.
Quote (MagicSmoker)
I am in 100% agreement with you about the old Tek THS-720P portable oscilloscopes, and I've even called up Tek once or twice to beg them to revive that product line. I still use the THS-710P I purchased brand new in 1997, despite also now owning its theoretically superior replacement, an AEMC/Metrix OX7104-III (but that is a tale for another post...)
I'm still looking for something to replace my THS720. I can't believe how Tektronix has fastidiously ignored this important area for the last 15 years.
For those of you who don't know the THS7xx series are a battery power-able handheld scope that's isolated between channels and between channels and the wallwart. It's a gem for scoping triggering circuits and the isolated power outputs. Triac, heaters, PWM, all those types.
Keith Cress
RE: MagicSmoker. LOOK! I got you another post.
I use the Metrix OX7204, too. That is the best performing portable four-channel scope I have had under my nails. The THS 720, I liked a lot. But it didn't have much software for the PC end.
But, mind you, even if those portable all-port isolated battery scopes can be used without problems almost everywhere, you still cannot measure across two motor terminals on a PWM driven motor. There, you either need an insulation amplifier or need to do N-A, N-B and N-C measurement and then do the A-B, B-C and C-A math in the scope. The 7204 can do that. There are well-known brands that aren't able to do that. So, I guess that the 7204 still is the winner in that league.
I haven't tried the available SW downloads yet. But I will do that one day when I feel lucky.
Gunnar Englund
www.gke.org
I'd like to have a play with Metrix type, just to see if it's as good as Gunnar says.
http://www.tek.com/oscilloscope/ths3000-handheld-o...
I want one. I need one.
I was just as excited as you. Then I read the specs.
No more than 15 waveform memories - although they can store four traces each. But still no more than 15 separate measurements. The rest (also limited) needs to be stored as bitmaps. I must ask myself, again: WHY on Earth economize on something as important as storage space? An SD card would have solved that problem.
The math I described above can't be performed. Not possible to use more than +, - and x and only one result channel. I usually need three to make Three-phase measurements.
Accuracy! Have a look at the specs:
Vertical accuracy
5 mV/div to 100 V/div ±(2.1% + 0.04 range/div)
2 mV/div ±(2.9% + 0.08 range/div)
At 1V/div you get +/-(21 mV + 40 mV) = +/-61 mV, which corresponds to around 6% error margin. I need better. Doesn't matter if you go to 100 V/div - same error margin. I wonder if this is a mistake. It can't be that bad.
But, perhaps it can. The automatic measurements are shown with 999 maximum Count. That is not impressive. A tru 3 digit display - not even a "3.5" digit display.
AC accuracy (results shown on the 999 display is:
AC coupled, high frequencies
60 Hz to 20 kHz ±(2.5 % + 15 counts)
20 kHz to 1 MHz ±(5 % + 20 counts)
1 MHz to 25 MHz ±(10 % + 20 counts)
So, if you need to measure a 1 V 1 MHz sine, you can't trust the result to be better than +/-(1V*10% + 20) = +/-120 mV or +/-12%. Again, I must ask myself if there is a mistake in the specs.
Vertical resolution isn't good either. Just 200 pixels. The screen is 320x240 pixels.
I was, as I said, also in need of one of these. But I cooled off quite a bit after reading through the data sheets and the manual. I don't even think that a super low price tag could lure me into buying one. Sorry. We do need better than that. I expect the Chinese to bring a decent and easily affordable scope on the market. In the meantime, my "French mistress" works well for me.
Gunnar Englund
www.gke.org
Have to take back any denigrations just made..
Nice find Scotty. <drool>
Looks like Gunnar's Metrix but less $$ and not noxious blue. :)
Keith Cress
Keith Cress
I may have been a little harsh on the screen resolution. But I think that the screen shots are rather ragged.
There is definitely more resolution and better accuracy with the AEMC/Metrix scope's 12 bit A/D instead of the THS and Fluke 8 bit A/D.
No touch screen, as far as I can see, on the THS 3000. And that makes many operations quite complicated. Like zooming and setting cursors and other common tasks.
What is the price of the THS3000? Can't find it.
Gunnar Englund
www.gke.org
Scotty's -28 Sep 14 12:27- post link IS THE PRICES.
Keith Cress
OK, those prices are not dramatically lower than what a French mistress costs.
Gunnar Englund
www.gke.org
Hope your spouse isn't reading this. :)
Keith Cress
She knows about my somewhat kinky relation to the OX7204. She even gave it a French name: Cri-cri!
Gunnar Englund
www.gke.org
Keith Cress
Gunnar Englund
www.gke.org
