Material for large pipe- No corrosion
Our client is installing a new pipeline very long and the corrosion rate calculation comes out to be zero.
Client is an Oil & Gas customer however the fluid is processed natural gas liquid so we do not expect H2S even in the long run. Should we still go for NACE compliance and corrosion allowance just because the pipeline is too long.
RE: Material for large pipe- No corrosion
You will find that in the construction of long transmission pipelines corrosion allowance is not normally built in.
So we assume no H2S at all..
Plymouth Tube
