Auto Balloon NX 8.5
Auto Balloon NX 8.5
After I Auto balloon a view in drafting I would normally place the balloon in a suitable location.
If the assembly gets updated for various reasons the drafting becomes out of date. when I update the drafting views the auto balloons move from where i positioned them.
Is there a way to fix these positions.
Manual ballooning does not seem to work for me . The procedure I used in NX5 was manual balloon a view and update parts list ,it would then populate the balloons with the correct number.
In NX 8.5 I cannot get the manual balloons to populate when I use the same method .Is there something I am not doing correctly?.
Thank you for any suggestions.
Jon
Jon
RE: Auto Balloon NX 8.5
And the behavior you are describing with the manual adding and automatic populating is still working for me in NX8.5
You do have to take care, while placing them, that the balloon leader is connected to the component (either an edge or a face of the component itself).
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
i just posted a video to our Vimeo site about parts lists that covers how to do that: http://vimeo.com/106565338
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.3, NX10 Beta
I have just added the variable and now manual ballooning works.
Thanks again for the info.
