Assembly constraints - linking through hierarchy levels
Hi folks,
I apologise if this has been addressed before. I haven't searched as I cannot think of the correct search terms to use. Please point me in the right direction if a thread already exists.
Using NX 7.5, I'm trying to piece together a linked assembly of an OHV valvetrain. The cam followers are in the parent assembly (constrained to the camshaft and cylinder block), the rocker arms are in the rocker shaft assembly (constrained to the rocker shaft and are free to rotate) and I'm trying to assemble the pushrods. What I'd like is for the position of the pushrod to control the rotational position of the rocker arms in the child assembly. Is this possible in NX as it just throws up a 'conflicting constraint' error whenever I try.
Many thanks,
Dave
Many thanks,
Dave
RE: Assembly constraints - linking through hierarchy levels
This will allow the movements in the subassemblies.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
...simple when you know (or in my case - get reminded) how.
Dave
