Create S-N curve with FEA
Hi, can anyone advise how to generate an S-N curve of a component using FEA?
Our company designed a product some years back, tested it in a resonance fatigue testing machine and generated an S-N curve.
Now we created a few variations of that product (similar geometry but different in size), and customers want S-N curves.
Putting each variation into a fatigue test is too costly for us.
Would FEA be able to help in this situation?
We make a living by what we get; we make a life by what we give.
RE: Create S-N curve with FEA
you might use FEA to compare different components (to show that the new ones don't have stress peaks not in the original).
Rob Stupplebeen
www.optimaldevice.com
change of material would be problematic, unless you have good fatigue definition of the two materials so you can say (hopefully) that the old material is conservative. if you don't have "good fatigue definition" then you're screwed ! and have to retest.
minor geometry changes could be resolved with FEA ... showing that the stress peaks are similar.
whyto say that the old s/n curves are applicable to the new parts." sigh ...another day in paradise, or is paradise one day closer ?
I'm giving a fictitious example to facilitate the discussion:
I use FEA and find out that:
The SCF of existing product is 3.
The SCF of new product (only changes in dimensions) is X, and the hot spot is in the similar location.
Now what can I comfortably derive if (1) X is close to 3, (2) X > 3 and (3) X < 3 ?
And what if I change the material, from 80ksi to 100ksi steel?
changing material can be very difficult to "hand wave". If you have a good fatigue definition of the two materials (s/n curves at several Kts) then you can build a story for adjusting your original s/n curve. if you have a good fatigue definition of the original material, then you should be able to use your s/n curve to derive a Kt.
baseline material data set.
My approach to the problem would be to get tests on axial specimens tested
in strain control. They are widely available, for your materials with
80 and 100 ksi yields(?) probably the AISI website
barsteelfatigue.autosteel.org
is a good place to start looking.
If you cannot find an exact match pick something with similar carbon
level and hardness or ultimate. Alternatively get someone to do a baseline
test series. Typical cost is probably $15k.
The reason for knowing your base material properties is that in fatigue
with on-going plasticity the materials can cyclically harden or soften
and large SCFs will throw your local stress-strain response into the short
life plastic zone.
For example method: Pick up the data from an HSLA 80 here:
fde.uwaterloo.ca/Fde/Materials/Steel/Hsla/mergedSAE980.html
hit the "Send " button at the top. You should get back a page with 3 plots,
the one in lower right corner is a "Neuber Plot" of the axial (unnotched)
specimen data. On this plot place the S/N data points (stress Range!) from your previous
tests. The vertical numeric value/ratio between the two curves is your Kt or SCF
multipier. You can also plot your old FEA predictions on this plot.
The attached file is a schematic of the idea.
Then do same for a 100ksi (yield) material and using you FEA estimated SCF
draw in the expected nominal or notched line below the axial result. Be
sure to "cut off" your notched curve at yield *2 (stress range) as this
method presumes that you are not going to get full plastic behavior in your
notched specimens.
Whether or not your customers will accept this as proof of durability
is, of course, another problem.
Thanks for your post. It's very helpful.
You also made a good point: acceptance from the customer. I foresee it's difficult to convince the customer. Do you know of any design code or specifications for such a problem?
Tough question regarding customer acceptance of an analytical
projection. Probably it depends on the safety issue of what you
are proposing. If it is a component that is safety critical, such
as a brake system in a vehicle, testing is obligatory. If one doesn't
test a safety item and something goes awry in a customer's hands the lawyers
will hang the engineers out to dry.
If it is not safety critical they may accept the analysis, but perhaps
increase their factor of safety on the loads.
Probably the best compromise is to do some tests, at least at the
higher amplitudes of the fatigue curve.
Remember when testing to start at a high load level and then work your
way down the curve. Short tests that take hours are much cheaper than
runout tests that take weeks. People forget that and shoot to hit the
fatigue limits. If they miss and it does not fail one has nothing.
I don't think there is a design code for this Neuber stuff. The approach
to the problem is used by the ground vehicle industry; though each company
has different ways of defining the same thing.
Incidentally the Neuber equivalent Stress range curve is for "R= -1" or
fully reversed tension compression testing. If for buckling reasons you
have to do something like a R= Smin/Smax = 0.1 test you will need to
correct for mean stress when you plot the tests. If you are nominally
elastic the Neuber equivalent stress range can be estimated by
Srange_equiv. = 2.0 * sqrt (Smax * Sampl.)
Good luck.
criterion may be: If your are building something like a machine of
which you only sell a few, and weight is not really that important, a
runout at worst load will show proof of durability. If the component
is something you will sell lots of, weight or $/lb becomes important
and one needs to know how far below the fatigue limit a runout is, and
revise the design for weight save; otherwise some competitor will offer
an improved lighter weight version.
Doug
i guess what you're saying with the statistics is that from a population of X specimens, we had Y failures, which a safe/max/mean/min life of Z. and from the "cloak and dagger" of statistics you can refer this result (from Y tests) back to the population for a safe/mean life.
Doug
1) create the flaw in a test piece,
2) do some DTA with the flaw,
3) live with 1/1000 failures (if you can),
4) proof load each production piece to prove a flaw doesn't exist, or to set up a beneficial yield zone around the flaws,
5) or something else ?
Doug
Doug
