trying to suppress by expression the detail view circle and note from main view
I would like to be able to define a detailed view that can be turned on or off by expression. I was able to get the separate detail to work, but I can't get the detail circle and note letter on the main view to suppress using the suppress drafting object commmand. I am wondering if there is another way to suppress these items.
RE: trying to suppress by expression the detail view circle and note from main view
Or maybe even increase the view scale by expression so the views itself, and the view label, moves outside of the view bounds and won't be seen
It will do exactly what you are looking for and more!
