Import initial velocity from previous analysis
Hi all,
is there a way to import the initial velocity field from the output of a previous analysis in Abaqus Explicit?
Thanks a lot
RE: Import initial velocity from previous analysis
Are you asking how to import velocity output data from one explicit analysis into the initial step of a new explicit analysis? Or have I misunderstood your question?
yes, that's exactly what I'm asking :)
Have you tried copying your original model to a new model and assigning an initial state predefined field (based upon the output from your original model) in the copied model?
