Sanitary Lift Pump Datasheet
Hey guys,
Can you tell me what are the applicable and required in the material section in the datasheet to input? or what the vendor can provide for the pump I described below. See attached.
I am preparing for the mechanical datasheet for a sanitary lift pump (fully submersible pump, most likely this will be a supplier standard type of construction. The process guy only indicated material for casing and impeller. I know guards and baseplate are obviously not applicable. Could you enlighten me?
V.
V.
RE: Sanitary Lift Pump Datasheet
http://www.pumpsebara.com/docs/DLU_tech.pdf
Just make sure you describe the function well, especially operation, number of starts / stops anticipated, any details you have on the fluid , e.g. dirty water, sewage, etc and then let the vendor determine what he thinks is suitable.
Then compare the offerings from different vendors and decide which is the best one and whether a more expensive pump with higher grade materials is worth it or not.
