Change/edit dimension in drafting mode in unigraphics
Hi all ,
I want to change/edit sketch dimension in drafting mode in unigraphics nx-8.0 without changeover in modelling.
Please help.
RE: Change/edit dimension in drafting mode in unigraphics
Do you want to change the dimension in drafting and let de corresponding parameter in modeling follow with the change?
Not the best practice would be the edit text option. Keep in mind the dimension is not associative any more, best change text colour to something different than standard.
Or you could leave the dimension as (maybe between brackets) is and add an Appended text before, after,.....
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
While not a recommended practice, it can be done. See thread561-149572: using a sketch in drafting.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
Much better link, Ben!
-Dalai Lama XIV
